A handy boat that can be rowed, sailed and powered with up to three large adults and can ‘nest’ to take up less space. This is a take-apart version of the standard PassageMaker dinghy.
Take-apart or ‘nesting’ dinghies can be disassembled to take up less space when stored on the deck of a yacht or in the garage. The Passagemaker Take-Apart is identical to the standard boat, except that the front 1.15 m (3′ 9″) unbolts and stows in the rear 2.35 m (7′ 9″). The interiors of both standard and take-apart versions are identical; there are no compromises made to rowing, sailing, powering, or towing ability in the take-apart design, although the take-apart weighs about four pounds more. Outwardly it's actually difficult to tell the difference between them.
We recommend 8ft oars for this boat.
The rowing hull kit includes:
- A pair of silicon bronze rowlocks and sockets
- Daggerboard case, built-in for future sailing upgrade
Broken inwales option
Broken inwales add elegance to any boat by mimicking the ends of the ribs in traditional frame-built boats. This option includes everything you need to install broken inwales in the Passagemaker Take-Apart:
- Pre-cut quarter-knees
- Rowlock riser blocks
- Inwales
- Spacer block material
Full Plans and Manual
This describes all of the techniques used during the building and also a step by step guide to construction. Scale drawings are used throughout as well as photographs of critical jobs.
This contains full sized drawings of the panels with the cutting instructions so it is possible to build the boat from scratch using these plans and manual. Note that these are large drawings.
Study Manual
Sailing upgrades
A sailing upgrade can be retrospectively fitted to the PassageMaker rowing hull to turn it into an able sailing boat. There is a standard gunter sloop rig and an alternative lug rig. Either sailing rig can be added to the boat at any time, even years after the rowing version is complete. Please note that the base kit (or a completed hull) is needed in addition to the sailing upgrade.
The larger gunter sloop rig comprises a 58 square foot mainsail and a 19 square foot jib.
The simpler balanced lug rig is quicker to set up, easier to handle and can be reefed or stowed more easily while out on the water. It's not quite as fast as the sloop rig, but it might win if you count setup time on the beach.
The sailing upgrades include:
- Sloop sails or lug sail
- Aluminium mast tube (sloop rig) or wooden mast blank (lug rig)
- Wooden blanks for boom and yard
- Mast step
- Daggerboard blank
- Rudder blank
- Tiller blank
- Blocks and cleats
The sailing upgrades do not include the warp – it is in the rope packages.
Sailing Rope Packages
The rope packages contain the warp. The sloop rig rope package includes sail lacing, main sheet, main halyard, jib sheet and jib halyard. The lug rig rope package includes sail lacing, main sheet and halyard.
