![Oz Goose low-cost plywood sailing dinghy that is easy to build and fun to sail](/photos/products/oz-goose/oz-goose-plywood-sailing-dinghy-4.jpg)
![Oz Goose low-cost plywood sailing dinghy that is easy to build and fun to sail](/photos/products/oz-goose/oz-goose-plywood-sailing-dinghy-1.jpg)
![Oz Goose low-cost plywood sailing dinghy that is easy to build and fun to sail](/photos/products/oz-goose/oz-goose-plywood-sailing-dinghy-6.jpg)
![Oz Goose low-cost plywood sailing dinghy that is easy to build and fun to sail](/photos/products/oz-goose/oz-goose-plywood-sailing-dinghy-3.jpg)
![Oz Goose low-cost plywood sailing dinghy that is easy to build and fun to sail](/photos/products/oz-goose/oz-goose-plywood-sailing-dinghy-5.jpg)
![Oz Goose low-cost plywood sailing dinghy that is easy to build and fun to sail](/photos/products/oz-goose/oz-goose-plywood-sailing-dinghy-2.jpg)
![Oz Goose low-cost plywood sailing dinghy that is easy to build and fun to sail](/photos/products/oz-goose/oz-goose-plywood-sailing-dinghy-7.jpg)
![Oz Goose low-cost plywood sailing dinghy that is easy to build and fun to sail](/photos/products/oz-goose/oz-goose-plywood-sailing-dinghy-8.jpg)
![Oz Goose low-cost plywood sailing dinghy that is easy to build and fun to sail](/photos/products/oz-goose/oz-goose-plywood-sailing-dinghy-9.jpg)
![Building the Oz Goose plywood dinghy](/photos/products/oz-goose/oz-goose-plywood-dinghy-construction-1.jpg)
![Building the Oz Goose plywood dinghy](/photos/products/oz-goose/oz-goose-plywood-dinghy-construction-2.jpg)
The Oz Goose is a low-cost sailing dinghy that is easy to build and is perfect for clubs, regattas and learning to sail.
Australian boat designer Michael Storer created this fun sailing dinghy as a project that makes dinghy sailing accessible to everyone. Where he lives, in the Philippines, family and corporate groups are able to build ten Oz Racers for the same price as importing a single Laser dinghy.
The Oz Goose is light and simple to build, with no complicated woodwork. It also sails extremely well despite the low cost.
The Oz Goose will carry an instructor and two adults for sailing lessons, or one or two adults for club racing. It is equally at home with two adults and children aboard for family picnics.
Kit
The kit is for the epoxy filleted construction method. An alternative timber-framed method is also described in the plans, for builders in countries where timber is cheap.
- Pre-cut wooden panels (6 mm plywood) with pre-cut joints
- Solid wood for gunwales, spacers and frames
- Mast staves (for hollow wooden mast)
- Wooden blanks for boom and yard
- Mast step
- Daggerboard blank
- Daggerboard case
- Rudder blank
- Tiller blank
The kit does not include the sail or warp although we can supply them.
Plans
The 114-page A4 plans for the Oz Goose are more like a book or a boat building course. They contain detailed information on each building step, including how to join the plywood, mark the shapes of the panels and use the epoxy.
The plans are highly detailed and fully dimensioned. That means that there is no poring over them with your scale rule and getting scale conversions wrong: the measurements you need to know are written in clear type and in the area that you are looking at.
PDF Plans
