Truant
The most fun you can have without getting wet.
Truant, designed for those who want to play hookey, is a very capable daysailer, with enough performance to be fun, small enough to go onto a garden trailer rather than a custom boat trailer, big enough to take a couple of less limber adults and their camping or picnic gear or a small mob of teenagers away for a small adventure.
She is so designed that she will be comfortable to sail, dry in most weather, capable beyond almost anything else of her size and almost impossible to capsize. Her wide beam and smallish centreboard cause her to slide off sideways rather than tip out, her generous freeboard and wide decks help keep the water outside where it belongs and she has so much enclosed locker and air tank space inside that should the unimaginable happen there is enough buoyancy to float her crew completely clear of the water when fully swamped.
The plans contain all of the information needed to build this boat. Fyne Boat Kits can supply the materials if any cannot be obtained locally.
